Engine mounts? They are huge!!!
glassjaw
Post by glassjaw »
Mine seem to be getting a little weak... time to replace!
I have a set just wasting space here that I took off a 1990 EJ22 (also wasting space).
One difference when you compare them to mine though...
THEY ARE F#*KING HUGE!
Honestly, they seem to have twice the rubber of my stock, and are larger than the WRX ones I have seen. They were replace on the engine, I can tell, they are in GREAT shape.
What are these things, why are they so huge? The rubber is round, BTW. I would imagine they could do a great deal to stiffen my engine....
But, what are they!?! Were these huge things stock in '90??
1998 Impreza L coupe...
Past Subies... 1999 Legacy L AWD, 1994 AWD L, 1992 AWD L, 1990 FWD L, 1990 AWD L. Pretty much all I drive.
magicmike
Post by magicmike »
Sounds like you've got some of the liquid filled ones there.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
glassjaw
Post by glassjaw »
Is that good or bad???
Odd. My EJ22 had square rubber mounts, but the turbo came with cylindrical ones. The cylinder-type seems stiffer, but that's just a 'squeeze-the-Charmin' observation as I didn't mount the cylinder-type (rusty) and reused my old ones when I swapped as they seemed fine.
morgie
Post by morgie »
the round "gel filled" ones are softer than the full-rubber square ones :/
morgie
'98 4Runner V6 Manual 4x4.
Post by entirelyturbo »
They're also a LOT more expensive, as I can personally attest to :(
*Formerly DerFahrer*
glassjaw
Post by glassjaw »
Softer? Hmm... even then they are still better than the crappy ones in there now :).
Would you recommend those over the square ones?
mhrallyteam
Post by mhrallyteam »
I've put grN mount on my engine, there is A LOT less engine twist under hard driving, and also A WHOLE LOT more noise, vibration and such when driving normally.
But for car nut like me the trade is really worth it, O.E. mount are way too soft
magicmike
Post by magicmike »
I've got the sti mounts in mine, paid around 100 bucks for them. I dont know how it was before because I never drove the car with the old mounts in but I can tell you now that it seems fine. Oh, the sti ones are square and hard.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Those STI mounts look like the regular mounts I have. The gel-filled are expensive, huh? Maybe I should sell them.
magicmike
Post by magicmike »
If I'm not mistaken I think I priced out the round ones at $130 a piece..... from the dealer
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
greg donovan
Post by greg donovan »
evolutionmovement wrote:Those STI mounts look like the regular mounts I have. The gel-filled are expensive, huh? Maybe I should sell them.
the GN mounts are much harder. you an barely push your fingernail into the rubber while the oem ones are almost jello like in comparison.
unfortunately you probably wont have much luck selling the hydro mounts.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
The funny thing.....the gel mounts are supposed to be softer, however I have held the square ones and moved them, and they do indeed feel softer then the round "gel" filled ones.
The sti ones actually have the same part # stamped in the rubber as the stock square ones, but the rubber compound is MUCH more stiff.
I think the gel-filled ones are supposed to be able to absorb vibration more than the rubber ones, which is slightly different from just being flexible.
greg donovan
yep the gel filed ones make your car seem like it has a smoother idle than it really does.
thats good to remember about the GN mounts having the same PN on them. they use the same mold for all the mounts just change up the rubber compounds. so if you get the GN mounts dont panic the PN are supposed to be that way.
96 Impreza L sedan
00 Impreza RS sedan
tris91ricer
Title Whore
Post by tris91ricer »
OK, i just asked Myles at RCE if the STi hardened mounts would fit a 92, as his site only says they fit MY93-04. Has anyone made the GroupN Engine Mounts fit a 92 or prior? I just talked with him via IM, and he said the only reason he made that revision was because he kept getting returns...
anyone here know if there is some kind of engine mount difference pre-93?
I really want GN mounts!
-=tristan
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
greg donovan
teagues sold me a set for my 90 and said they would fit. havent put them on yet, though. however, my subaru mech. said they would work too.
96 Impreza L sedan
00 Impreza RS sedan
I know the pic sucks, but here's the sti mounts sitting bolted to my car
http://www.main.experiencetherave.com:8 ... P_3289.JPG
I don't know why he would have people returning them unless they look at the mounts and see they're different.....and think they don't work. The mounts will work on any EJ series motor.
greg donovan
the only reason i can think of for returning would be NVH or they decided it was too hard to put them in. i mean you have to do sooo much work. im kidding of course. about the work part but im sue some feel that way.
96 Impreza L sedan
00 Impreza RS sedan
BAC5.2
Post by BAC5.2 »
The Group N mounts work on ALL EJ engines. They are all the same.
Myles has the 93-04 Impreza listed. That's why. I'm sure people returned them because they had hydro mounts and the PN's were different and/or they looked different.
Definately go for Group N mounts. They are a great upgrade. But they increase NVH by a sizeable margin.
mhrallyteam
The GrN, which are STI too, fit perfectly on a 92 legacy.
greg donovan
mhrallyteam wrote:The GrN, which are STI too, fit perfectly on a 92 legacy.
yes the GN mounts are by STi, however the problem arises if you just order STi mounts you wilol get the mounts for the STi which are not the same as the GN mounts. i think they are stiffer than the other mounts but not as stiff as the GN ones.
96 Impreza L sedan
00 Impreza RS sedan
J-MoNeY
Post by J-MoNeY »
I just scored a set of STI mounts for me car for free. Is it really worth the time to put them in?
98 LGT
No. Send them to me instead.
J-MoNeY
Post by J-MoNeY »
Deal. I'll pay shipping too.
98 LGT
