Just for fun, I pushed the mph limits of the car
OK, this morning on my way to work, I decided to push the car and see how the top end feels. Mind you I commute to work 30 miles of open 2 lane highway with no one on it ( my only fear is deer at this time of the day).
At about 125, I decided to let off because I ran out of straight roads.
But DAMN it was smooth. And I still had another 1250+ rpms to go- and she was still pulling.
NOW, if I only had a 6 speed...........
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
What do you need a 6 speed for? Your last three gears are nearly indentical. You need more power, or better aerodynamics.
My baby used to be able to do 120-125 easily
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
The six speed would allow me to add another lower overdrive gear.
I think she could do 130, but am curious if I could actually get the speedo to see the 140.
aerodynamics/drag vs power
05 GD-STI
00- GF
05 GD-STI
00- GF
- Spelling Nazi
I've had my SS up to 133-134 mph down on I-270 north of DC. She was still going strong when I shut her down too. I could have pushed her further.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I've seen 133. My old GL used to go faster in 4th than 5th.
Scott- Is that a challange, mang?
I was still accelerating (although slowly) when I shut it down at 133-134 mph. I'm positive I could have pushed it further, probably not much further but maybe the 136-137 range.
This was also on a stretch of freeway that is dead flat for about 8 miles.
My tires were OEM at the time too.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
So you'd build a custom 6 speed just to make 140 mph?
The usdm 6th gear ratio is .756, the final drive ratio is 3.900
Your 5th gear ratio is .738, your final drive ratio is 3.900
You wouldn't be adding a lower final gear you'd be adding a higher final gear. I say again, you dont need a 6mt
I can push through 3rd and to the top of 4th.
I'm confident that I can reach the physical limitations of the gearing of the vehicle.
I dunno if I'd make that claim. You've got less horse than an sti and they top out at like 150 right? (powerwise, not gearwise) They're also better aerodynamically.
My wagon was off a full 10% with the stock tires. So the one time I hit 127 I was actually about 115. Big difference.
Now with the WRX tires and rims I am about dead on and have hit 120 once, only once because that was damn fast and I was having fueling issues.
I'm basing it on the haste that I clear 120mph. It gets there pretty fast.
I'm sure I'll find out one day.
I don't doubt you get to 120 quicklike, hell maybe even 130, but 163? You need a lot of power to move that fast. Doesn't wind resistance increase exponentially?
Drag increases at the square of speed.
I don't think an STI is better aerodynamically to a Legacy sedan. That wing, especially, creates a lot of drag. Still, I'm not sure about 163 either. Maybe with the mirrors pulled, seams taped, and some openings blocked. Some undertray and possibly rear skirts would be helpful, also.
I dunno about the new impreza's but our drag coefficient is actually pretty low, especially for when our cars were produced. It's like .32 isnt it? Our drag coef is good but the frontal area is fairly large.
The top part of the wing creates drag, the bottom part creates downforce. The top part is for stability.
I do believe the svx is still the fastest subaru in america. Topping out at 154mph in 92 and 93 versions. Reason being is the .29 drag coef. And apparently with the non-usdm uncar cover the drag coef is .285
I agree. The round fenders n such just make more surface area.evolutionmovement wrote:Drag increases at the square of speed.
In reguards to the 5 vs. 6 speed arguement. The 6 speed is much more durable, in every aspect. Downside, it weighs a helluva lot more.
