removing piston pin (wrist pin)
I started braking down my extra block yesterday, and had to stop when I got to pulling the wrist pins out. Is there a way to get them out, besides the remover tool?
Just a little hint to people that can't find a 14mm hex wrench.
A bolt with a 14mm head and vise grips work great.
Troy
P.S.
the block still has cross hatching after 200K+
Troy
P.S.
92 legacy ss 4eat
- quasi-mod-o
Matt Monson
- quasi-mod-o
I made my own tool from a clothes hanger. But if the engine has been overheated or is super old, they can stick pretty bad. If you can't pull them out, you can actually push them in far enough to get the piston out and then crack the block with the pin still in the rod. I had to do this on 2 of them on my EJ25.
We will be doing a tranny swap at my place on Saturday. If you are coming to town and want to throw your block in your trunk and bring it by, feel free. Just call me to give me a heads up first...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
douglas vincent
I called him this morning and hopefully he will be able fabricate the tool I described over the phone.
I've made several tools successfully in the last few years. I've used a TIG rod slightly larger than a coathanger but found it bends too easily. I even tried hardening it a little to no avail.
I took a small piece of threaded rod and put a low profile nut on it. That worked the best because I can put a big rubber weight on the other end with a nut and washer to use it as a slide hammer..
I took some rod and ground a groove into the edge. This one didn't work well on the pins but I still use it to remove dowels on heads I port.
I also welded a small washer on a piece of rod. This worked well. (Gave that one away).
-Michael
-Michael
