Factory ECU chipping effort...
azn2nr
Post by azn2nr »
when my friend did a 96 wrx swap which is bascily the v2 without the red manifold, the coil pack, maf sensor,map sensor and the boost contorl solenoid were identical to my legacy. i can see how the chasis harness may be a problem but i think it should be able to run the car properly
-jason
MY92
Post by MY92 »
I haven't sifted through all of this thread yet.
But you guys know that ther eis a 8bit and 16bit ecu?
John
http://www.cardomain.com/ride/560635
On non-North American models, yes. All North American Legacy Turbo ECUs are 8-bit. But the North American 8-bit ECUs are completely different from the other 8-bit ECUs. Ours are made by Hitachi; yours are made by JECS.
MY92
Post by MY92 »
Good stuff :)
I'm currently playing with JDM 16-bit ecu to run with more fuel, so fingers crossed I can get a half decent tune with larger injectors on factory ecu.
John
NICO
Post by NICO »
one think is our north american ecu shit.
hackish yes i was on that board they are all jelouse pepole on the gtx borad and did not belive me or my legacy turbo could be that fast bunch of monkeys
if you need and help let me no
