Torque bind
zapjackson
Torque bind
Post by zapjackson »
Ok, i know this has been discussed probably to many times, but i have searched and searched, but can not find what i need to replace to get rid of the torque bind. Do i need to replace the center diff.? Help me out here. Oh and i have a '92 legacy wagon N/A.
greg donovan
Post by greg donovan »
the clutch pack in the center diff.
have you changed the fluid yet?
try the amsoil synthetic ATF it helps.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
zapjackson
I thought that the higher mileage subaru trannys didnt like the synthetics? I have 186k.
greg donovan
mine has 240,000 and my sub tech said it would be ok. but if i were you i would look into it more myself.
the new subaru ATF is pretty good too.
96 Impreza L sedan
00 Impreza RS sedan
93Leg-c
Post by 93Leg-c »
TOPIC: 94 AWD 4EAT tailshaft extension building
AUTHOR: Adam Lee
LAST POST: Mon Nov 15, 2004 7:00 pm
You might want to peruse the above thread. I didn't know how to copy it over so I had to type everything in.
'94 TW
