Will 03 Outback seats fit my 93 Wagon?
gustavohuber
Hi there, my driver's seat is worn out in a funny way which makes my hip hurt after a bit, and I sourced a pretty sweet set of '03 Legacy Outback seats with power thingies..
A) will they fit the mounts in my 93 wagon?
B) will I be able to power them so that they do their thing?
Thanks!
/Gus
Thanks!
/Gus
ex-devastated ex-owner of the $5500 parts car!
I don't know about the fitment but I would think powering them shouldn't be much of an issue, assuming the controls are on the side of the seat (couldn't see them not being). You might have to splice a few wires and possibly run a few wires from the fuse box to power it though. Do the seats have power specs anywhere on them? My guess, just an educated guess, is that they probably draw enough amps that it'd be best to have them powered directly from the fuse box, someone with a little more off hand knowledge could probably tell you which circuit to tap into. BTW, that's one low milage Legacy you got there, nice find.
Lee
LaureltheQueen
- Spelling Nazi
tris91ricer
- Title Whore
What's wider? The svx? Yes, but so is a second gen impreza...
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
tris91ricer
- Title Whore
mm. okay, well, I have no response.
Too bad wrecked L.L.Beans are hard to come by, and especially in the leather trim. It'd be awesome, though. I keep seeing those sexy Outback Sedans, which I really like, and they've got bucket-style backseats in some pretty spiffy looking leather. I'd cream myself everytime I'd get in the car if those were in my Legacy. And the power makes 'em even cooler. I'd gladly sacrifice the weight for the roll-clean-and-comfy factor.
Bliss.
Bliss.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
Sorry I'm late to this topic, but before you swap to LL Bean seats you should try the passenger one. Nobody really cares about the passengers ass, but I find it unsupportive for legs. I'm about 5'11 and anyone taller seems to have this problem as well. The driver's adjusts enough to pretty comfy though.
And since the power could be wired up, I assume the heaters could be too? Dual stage butt warmers, mmm.
legacycontinues
- Voluntarily Dismissed
kastrix
Our 05 Aviator has 5 levels of heat and A/C. Only on the front two seats tho. The jag has heated front and rear seats but only one level.
@The Beast@
1992 Legacy L 5MT
Exhaust, tint, fogs, anti-snorkus, plugs, wires, rims, tires, stereo and shifter knob :-)
A good car is like a good woman...
She will turn on when you want her to and she will always give you the ride of your life.
1992 Legacy L 5MT
I just tried to swap a set of 97' Legacy Outback seats into my 91' Legacy wagon and it would have worked but the seat belt shackle is not the same. I tried to swap the tracks but the newer model seat had a manual height adjusment that prohibited that from happening. If you can swap the seat tracks onto the new seat I would do so because the seat belt buckle is also connected to the track.
1987 VW Westfalia Vanagon - EJ22T Powered
1994 Legacy Touring Wagon
