HELP ME!!...please
92turbolegacy
HELP ME!!...please
Post by 92turbolegacy »
despite my attempts to locate the CEL black connectors i have not been able to find them...i followed everything step by step and looked for over an hour and a half but still no damn luck. i was using this website to help me, http://www.surrealmirage.com/subaru/engine.html but it seems the underside of my car looks compleatly different than the one in the pictures. i own a 1992 legacy SS 5MT. could someone please help me, i've read all the forums i could find but still no luck. any help would be greatly appriciated.
1992 Legacy Sport Sedan
Look to the right of the steering column.
92turbolegacy
i have, i looked everywhere under thier...left,right, up, down, backwards, you name it....mabey im just going blind
magicmike
Post by magicmike »
they might be taped up with green tape to a harness either on the right side near the obd plug or on the left side of the steering column taped to one of the harnesses that plug into the ECU. If I'm not mistaken they should be on the right.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Flip_x
Post by Flip_x »
i found mine more to the right of the steering. almost near all the radio wires. try that.
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
92turbolegacy
AHHHHHH......i found one black connector on the right....the green ones on the left on i cant find the 2nd black one...time elapsed in looking for them....5-6 hours..im going nuts...i cant find the sencond one..i've untaped all sorts of stuff but nothing...im begining to think im screwed.
If all else fails you could just jumper the "test mode" and/or "read mode" pin(s) of the ECU to ground directly.
92turbolegacy
How do i go about jumping the test mode?...
Refer to these pinouts: http://www.graphics.cornell.edu/~v/ecupins/
Connecting pin B56.12 to ground is equivalent to hooking up the black connectors.
Connecting pin B56.13 to ground is equivalent to hooking up the green connectors.
