Titanium head studs
scoobydoo
Titanium head studs
Post by scoobydoo »
HA! got you to read my post. :P But seriously folks i need to know if the head bolts can be reused on a legacy turbo. Yes, ive searched and there seems to be a group that thinks you should and a group that says you shouldnt. What does the factory manual say? Im about to assemble my engine and im stuck here. please help me out guys.
thanks.
-Jose
The FSM says to replace.
I've been told by CCR Engine rebuilders that have quite extensive background rebuilding subie engines that you can re-use the bolts.
I don't know if the torque procedure is different though. May want to give them a call www.ccrengines.com
scoobydoo
Post by scoobydoo »
Thanks josh.
JasonGrahn
Post by JasonGrahn »
you can re-use them once. must replace if you go for a second time.
-Jason Grahn
