Looking for rims... what lug pattern/offset fits?
Guy in my area selling some nice 5 spoke 17" rims with tires off a New Mustange (4.5 on 5 lug pattern) Being a RWD car I figure the rims wont fit my Legacy but brought up a good question.
What is the Lug pattern and Offset for a legacy?
Any 5 lug subaru wheel will fit with the exception of the new STi's. As far as size, most people like to upgrade to 16's. You can usually find good deals on used WRX stuff or RS stuff. You can run a 215 on a 16" rim without rubbing issues but if you decide to step it up to 225 you will probably end up having to roll your fenders. I'm running the stock turbo rims, 15", with a 205/60 and it works great for me. Sticks well but has enough give to allow me to drive up in the mountains. I'm wanting to say the offset is either 48 or 53mm. If you do a little bit of searching you'll find lots of info and if you go to the gallery and search for rims you'll find all sorts of inspiration.
Lee
- Title Whore
WRX's also have wider fenders.
A 225/45/17 on a 17x7.5" + 48 rim fits without rubbing anything without rolling the fenders (even lowered, they clear with room to spare).
225/45/17's REQUIRE fender rolling on our cars with a 17x7.5 +48 rim.
It's more a rubbing issue than a wheel bearing issue, though to a point there's a limit.
- Title Whore
Well, since we're on the topic... say I was getting 16x7 Rota Slipstreams, 5x100 bolt pattern, 48mm offset. What tire size wouldn't require me to do anything to my fenders? Or an all-around better way of stating the question: what tire size would be best?
[url=http://www.cardomain.com/ride/762395]1990 Legacy L (Sold)[/url]
[url=http://www.cardomain.com/ride/2564067]1992 SVX LS-L[/url]
[quote="LaureltheQueen"]I like my automatic, it's fun to drink coffee and smoke civics at the same time[/quote]
I don't have 16's but from what I've been able to figure out from others, 215's will work just fine and as Phil said, 225's will require rolling the fenders. That's something however that you can do fairly easily if needed.
Lee
Only the sedans have wider fenders and I thought that was just to allow wider axles. Since as you can see by looking at a sedan and a wagon that the wheels line up the same distance to the fenders. So if a wrx, or rs or sti for that matter, in sedan form can have a lower offest, then a wrx, or rs or ts, in wagon form can too have a lower offset, right?
Also, did you make a mistake on the tire sizes or something?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Yeah, I'm thinking he did... here are the options (unless for some reason more money should be spent on getting the wheels and tires separately):
205-50-16
205-45-16
205-40-16
But as I know zero about tires... yeah.
205-50-16
205-45-16
205-40-16
