(this is for a '91, YMMV)
- WRX gearbox
- Legacy Turbo driveshaft
- WRX rear diff
- WRX SEDAN (wagon does not fit, too short) rear axles
- Legacy Turbo front axles
Swap the linkage from the legacy over to the WRX tranny and you should be all set. Just need to helicoil a stud into the tranny for the starter, thats it. Pretty easy. Shifts NICE for once. The Legacy tranny will be rebuilt for experience then the WRX tranny will get RA gears.
