ej20g timing belt install help
snowjob
Post by snowjob »
So I've decided to do the timing belt on my ej20t and just want to confirm I'm doing everything right.
BeforeI took the belt off, the turbo side cams both exhaust and intake were not really lining up, they looked off by about a tooth.
Here is what I did, If i've made any mistakes, please correct me before I start her up.
1. took the plug out of cyl. #1 and put a compression guage in their.
2. turned the crank via the front crank bolt until I started to get compression on the guage, then lined up the marks on the crank with the block.
3. took off the idler pulley
4. took off the tensioner(at which point **** hit the fan and both intake cams moved because of the tension taken off the pulley)
5. Using the manual, I rotated the cams back to where they should be, making sure to only turn them the way the book indicated.
6. So here is where I'm at right now, the turbo side exhaust and intake cams cyln 1,3 have no pressure on them, as in they are not pushing any valves down, but the other side, ie. cyl #2,4 cams are under pressure, as in they are pushing down valves.
Is this correct?
Also, what timing belt should I use. will a wrx work?
Thanks for any tips I may have missed.
Frazer
04 modified XT
99 LGT Limited
ej22t
Post by ej22t »
It should be the same as all 4 cam subaru engine. YOu could use the WRX one and I belive you better buy it from dealer since it won't have a lot cheaper from aftermarket.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
snowjob
Post by snowjob »
Ahh not true my friend, dealer is $285new and aftermarket is $56 as long as they are ok, then i'm going to go ahead with this.
04 modified XT
99 LGT Limited
THAWA
Post by THAWA »
Are you sure you're not looking at the STi timing belt? A WRX belt is like 130 from the dealer, and just under 100 from subaruparts.
Are the marks lined up still for 2 and 4? If so you're fine, just rotate them one at a time until you unload the cams. I do believe in both DOHC and SOHC when the right side is unloaded the left is loaded, and vice versa.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
snowjob
Post by snowjob »
Thanks man, you are the only one in four forums i have this in that answered that question. YOU ROCK.
04 modified XT
99 LGT Limited
THAWA
Post by THAWA »
I saw it on three of the forums :). RSLC, Nabisco, and here, where was the other one?
mikec
Post by mikec »
RSLC?
snowjob
Post by snowjob »
www.rslibertyclub.org
Aussie version of our board.
04 modified XT
99 LGT Limited
snowjob
Post by snowjob »
you got all three, number four is www.toronto-subaru-club.com
I'm from ottawa, but the spda-online.com just doesn't cut it as far as boards go.
04 modified XT
99 LGT Limited
snowjob
Post by snowjob »
For everyones info the correct belt for a ej20g is a Gates t277. The same belt as a 98 2.5 RS.
Thread closed.
04 modified XT
99 LGT Limited
