Hey you brainiacs,
I found this DIY FCD, just wonder what you think?
http://www.teamfc3s.org/info/articles/fcd/diy_fcd.htm
another DIY FCD and other DIY links of interest
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
I just found something else VRG3 may be intersted in, I recall a post about a throttle controlled FCD?
anyway found this article on DIY BOV and it has info about a gadget that monitors the throttle position sensor
http://autospeed.drive.com.au/cms/A_2181/article.html
wow this guy has some great writeups on Turbo DIY stuff. I'm too tired to keep reading so you guys have at it.
http://www.xmission.com/~dempsey/perform/
That design is a lot like my initial design. My revised design is a little better, I think, because the offset voltage has a slightly smaller effect. Mine also has a lower output impedance, though that shouldn't really matter in real life.kidwired wrote:I found this DIY FCD, just wonder what you think?
Scott's probably right that a low-pass filter on the input is a good thing. It couldn't hurt to stick one on the input of my FCD.
If you do decide to build this one, don't use an LM358 as they suggest. It's only rated for 0 to 70 degrees Celsius. The LM224 is basically two LM358s in one package but with a wider temperature range.
Scott wrote:It just seems like a potential headache
You can actually eliminate the pot if you just pick some appropriate resistors though.
That gadget is similar to what I described in the thread about a TPS-controlled MBC but with a timer attached, but based on the rate of change rather than the position.kidwired wrote:anyway found this article on DIY BOV and it has info about a gadget that monitors the throttle position sensor
Yeah, the mini-Mopar crowd was one of the first to start doing easy cheap mods on factory turbo cars. Very cool.wow this guy has some great writeups on Turbo DIY stuff.
