Turbosmart FCD, any good?
mhrallyteam
Post by mhrallyteam »
I've seen the turbosmart pneumatic FCD, it works with MAP controlled fuel cut. It taps in the pressure line and seem to bleed air at a certain pressure, a little like Morgie`s fcd.
Are they any good for our application, i know that vrg3 FCD is good, but i suck at soldering and found an affordable turbosmart FCD. THX
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
It should work fine. From what I understand it actually uses a small enough bleed orifice that it can raise the overboost threshold rather than eliminating fuel cut altogether.
azn2nr
Post by azn2nr »
how much is it???
nuand made one for me but it didnt work as well as i hoped as it pushed fuel cut back but not far enough.
im using a small similar valve that has a 7 psi minium release that i got for 15 bucks. works just fine.
-jason
BAC5.2
Post by BAC5.2 »
I am using a VRG3 FCDII, and haven't had any overboost related problems for quite some time.
free5ty1e
Post by free5ty1e »
<-- VRG3FCDII installed and happy for quite some time now. Regularly boost (when clutch is happy) above 13 lbs for > 3 seconds and everything = AOK
-Chris
91SS 4EAT stock, 200k mi
