Will STi injectors work?
ShaggyGT
Post by ShaggyGT »
Ok, so I am fairly new to the forum. I just purchased a '91 Legacy Turbo sedan. I have been considering a few different paths for mods already, as I have done with every Subaru I have owned. I was considering injectors when the other day I thought about the USDM STi yellow top injectors. I have an '05 Legacy GT right now which has those injectors stock, and I am in the process of doing a large build on it so the stockers will be coming out. So would they work in the Legacy turbo or would I need to get a different type of fuel rail from another Suby? From what I have seen of possible upgraded injectors that could possibly work, it would seem the STi injectors would work perfect. What do you guys think?
-Matt
1991 Legacy Turbo Sedan
2005 Legacy GT Sedan (STi Conv.)
-K-
Post by -K- »
They should fit with the 92-94 N/A rails. I have fit some nissmo 440cc injectors in those rails and they claim fitment on STi's.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
azn2nr
Post by azn2nr »
most side feed high flow subuaru injectors and nismo injectors will fit on 92-94 NA rails which subsequently fit on the turbo as well
-jason
ShaggyGT
Post by ShaggyGT »
Awesome. So looks like I need to find some N/A rails for sale. I take it just about any N/A Subaru fuel rails for those years will work? Thanks for the replys.
-Matt
ShaggyGT wrote:Awesome. So looks like I need to find some N/A rails for sale. I take it just about any N/A Subaru fuel rails for those years will work? Thanks for the replys.
-Matt
You need 1992-1994 legacy n/a fuel rails. They must be between those years, and they must be from a legacy. MT/AT doesn't matter.
It's possible the 93-94 impreza might have the same injectors, but I have absolutely no way to confirm that.
BAC5.2
Post by BAC5.2 »
Josh - The EJ18 rails fit the usdm STi injectors, and I'm PRETTY sure that they fit on the EJ22T.
ShaggyGT
Post by ShaggyGT »
Ok thanks!!! So am I better off checking out the closest U-Pick It yards or is there some place online I can locate them?
-Matt
BAC5.2
Post by BAC5.2 »
Go to a pic-n-pull first. Rails are wicked cheap. You could probably get both rails for under 20 bucks no problem.
azn2nr
Post by azn2nr »
the part numbers on the imprezza rails are off by one number. but from the looks of it they are the same.
i have 2 sets of rails, one from an imprezza and one from a leg na. ill be selling one shortly but they wont have the thing that holds the injector down. one of the sets is missing this part. im sure youll be able to get them at the delear for cheap
-jason
IronMonkeyL255
Post by IronMonkeyL255 »
Hmm....... My brother has an n/a '94 legacy.........
I think he's going to be getting some LT rails once I get some STi injectors.
Rio Red '91 Legacy SS
ShaggyGT
Post by ShaggyGT »
Let me know when you are ready to sell those rails. I will definitely take those off your hands.
-Matt
azn2nr
Post by azn2nr »
for sure. i could probaly let them go by the end of the week
-jason
THAWA
Post by THAWA »
Incase you didn't know, and I just found out not too long ago :). Sometime in the last 6 years FHI raised the fuel pressure from 36.3psi to 43.5psi. So if the injectors you are about to install are 440cc/min then that would actually be a downgrade of 3cc/min using the stock pressure. If they are 480cc/min then you're looking at 30cc/min more at the stock pressure.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
azn2nr
Post by azn2nr »
wait what????
if the pressure is increaced than wouldnt it be even more fuel???
-jason
THAWA
Post by THAWA »
Yes. Reread what I posted. I think you may be confused.
azn2nr
Post by azn2nr »
oh, you mean if you put big injectors in the stock rails right???
the fpr's that are on the na rails are vac fed so they should be usable.
-jason
THAWA
Post by THAWA »
I think you may still be confused. All our Legacys have 36.3psi as the fuel pressure. Newer Subarus have 43.5psi as the fuel pressure.
azn2nr
Post by azn2nr »
yeah, so how is the 440cc injectors a downgrade.
-jason
douglas vincent
Post by douglas vincent »
I think he is saying that they are rated at 440 at 43 psi.
Just upgrade to a walbro fuel pump. I have and am running 40plus off boost and 3.5 bar on boost.
THAWA
Post by THAWA »
Right, 440cc/min at 43.5psi, which is 367cc/min at 36.3psi. Conversly, putting a 43.5psi FPR onto a Legacy would yeild 443cc/min
azn2nr
Post by azn2nr »
cool. good thing im gonn use the na fpr's.
-jason
THAWA
Post by THAWA »
You still aren't understanding what I'm saying. The Legacy FPR is 36.3psi, turbo or NA. Changing to one isn't going to do anyhting unless your stock one is knackered.
azn2nr
Post by azn2nr »
it will if i use the imprezza rail
oh and if this is so how do you explain jake runnin as rich as he did as he was using a ss fpr
-jason
THAWA
Post by THAWA »
What year impreza?
what injectors was jake using?
azn2nr
Post by azn2nr »
jake was using yellow 440's
the imprezza was problay 98 ish.
either way, its still a pretty easy fix
-jason
