TD05 from Early WRX to Legacy Turbo
I have a 93 us spec legacy turbo and I was thinking about upgrading my turbo. I know the td05 creates low end lag, but that doesn't bother me. I just want to know if the early wrx td05 turbo is a direct bolt-on. There's been a lot mentioned about using this turbo, and i just want to have things cleared up once and for all.
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
Actually the compressor side is nearly identical to the turbo that came off my car...oil and water lines also bolt right up. Exhaust side is teh same too..all Subarus use that same flange design for the up-pipe and downpipe sides..the TD05's have a slighltly shalower exhaust housing than the IHI tubros, but that only comes into play if your downpipe has a seperator in it (ala BPM). I ran into no isses at all using the HKS downpipe for a new WRX on my car..just needed to extend the O2 sensor wire roughly 5 inches.
However, this turbo flows considerably more air than the stock unit, so an intercooler would be a mandaotry addition to the turbo. Ding this is pretty straightforward, albeit a bit time consuming....basically a matter of rerouting vaccum lines. I did the swap almost all myself (with some help from one of my shop's employees) over the span of 2 days.
'91 BC5 Turbo, modded :)
So the TD05 will bolt up without having to modify the upipe flange? How much boost is this turbo rated for? How about turbo lag, is it much? BTW Adam, significant interest has been shown for the 93-96 WRX intercoolers, I think its something like 8 people now.
Mark,
Mark,
Up-pipe is eactly the same. It is important to note that this is a TD05 16G turbo for an early WRX, not for an Eclipse, or other Mitsubishi (which use the same basic internals of this turbo, but different housings/flanges).
Lag will vary greatly on the rest of the setup. On my own car (3 inch HKS downppe, high flow cat, 2.5 inch catback), lag is really not much worse than the stock turbo. The difference here is airflow...this thing vastyl outflows the stock turbo, as well as many of the IHI turbos that are upgrades" for Subarus. I keep mine at bar everyday, but you can reliably use it to about 17-18 psi without harm, so long as you ahve the fuel to back it up, and of course, the proper mapping of the ecu.
OK, here are the turbo and IC prices. Have to check my suppliers stock, but he knows for sure he has 5 of each at a minimum. These items are used, but fully inspected and guaranteed to to be in good sound operating condition. I have dealt with this firm personally for awhile now, and have boght everything from trannies and motors, to teh intercooler and turbo i am running curently on my Legacy Turbo...so in other words, I trust him implicitly (sp??)
TD05 turbo: $375.00
Intercooler to suit above (comes with piping): $300.00
Prices include shipping from my supplier oversas to us (hence the slightly high prices), but do not include shipping to th end buyers...shipping costs would range from $10.00 to $20.00 for the 48 states via Fedex Groujd depending on your proximity to NY.
Adam
Z-1 Performance
www.z1auto.com
TD05 turbo: $375.00
Adam
Z-1 Performance
www.z1auto.com
will this ic work with the stock legacy turbo,or do you have to get the TD05?i know it wont just bolt on but can it be made to fit the stock turbo?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
what do you mean by that? smaller in size or smaller in depth? the latter i suppose, since you mentioned it flow more. do you happen to have a flow comparison chart of say the vf series turbos vs. mitsu td turbos?the TD05's have a slighltly shalower exhaust housing than the IHI tubros,
92 Legacy Turbo \ 5MT \ Silver
Is a TD05 the absolute biggest turbo we can fit in our car? (DIRECT bolt on) Assuming that we have enough extras to back it up. (i.e. IC, fuel etc)
Mike
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I recently took possession of Adam's car. I must say, his descriptions of the car's performance were right on the money!! Spool isn't anything I'd call as frustrating, and it seems to take the the TD05 very well and without any type of piggyback fuel controllers other than an HKS FCD. I'm gonna try out a S-AFC after the holidays and take the car to get tuned/dynoed at TurboXS . . . I'll let you know what I find out (powerwise anyway).
FWIW, Adam gave his best estimate at a mid-13 sec car . . . I believe him, judging by some random run ins with a Mustang GT and a GS400 over the weekend.
Jason
Jason
Got this off the nasioc board. I'm not sure just how accurate the approximations made on some turbos are, but the TD05 even with the "small" compressor flows alot more air than the WRX TD04:
Turbo Type Approx flow @ pressure
Stock Turbo 360 CFM at 14.7 PSI
IHI VF 25 370 CFM at 14.7 PSI <--- estimated
IHI VF 26 390 CFM at 14.7 PSI <--- estimated
T3 60 trim 400 CFM at 14.7 PSI
IHI VF 27 400 CFM at 14.7 PSI <--- estimated
IHI VF 24/28/29 410 CFM at 14.7 PSI <--- estimated
========= 422 CFM max flow for a 2 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 RPM =======
IHI VF 23 423 CFM at 14.7 PSI
FP STOCK HYBRID 430 CFM at 14.7 PSI <--- derived from HP potential listed on web
IHI VF-30 435 CFM at 14.7 PSI <--- estimated
SR 30 435 CFM at 14.7 PSI
IHI VF-22 440 CFM at 14.7 PSI <--- refigured
T04E 40 trim 460 CFM at 14.7 PSI
========= 464 CFM max flow for a 2.2 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 rpm =======
PE1818 490 CFM at 14.7 PSI <--- estimated from max flow numbers
Small 16G 505 CFM at 14.7 PSI
ION Spec (stg 0) 525 CFM at 14.7 PSI <--- per vendor post 12-27-2002
========= 526 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 RPM =======
Large 16G 550 CFM at 14.7 PSI
SR 40 595 CFM at 14.7 PSI
18G 600 CFM at 14.7 PSI
PE 1820 630 CFM at 14.7 PSI <--- estimated from max flow numbers
20G 650 CFM at 14.7 PSI
SR 50 710 CFM at 14.7 PSI
GT-30 725 CFM at 14.7 PSI
60-1 725 CFM at 14.7 PSI
GT-35R 820 CFM at 14.7 PSI
T72 920 CFM at 14.7 PSI <--- Note you would have to spin a 2.0 L
engine at about 14,000 rpm to flow this much air.
IHI VF 25 395 CFM at 18 PSI <--- estimated
IHI VF 26 400 CFM at 18 PSI <--- estimated
T3 60 trim 410 CFM at 20 PSI
IHI VF 27 420 CFM at 18 PSI <--- estimated
IHI VF 24/28/29 425 CFM at 18 PSI <--- estimated
IHI VF 23 430 CFM at 18 PSI <--- estimated
IHI VF-30 460 CFM at 18.0 PSI <--- estimate based on trap speeds of cars running this turbo
AVO 320HP 465 CFM at 17.5 PSI
T04E 40 trim 465 CFM at 22 PSI
FP STOCK HYBRID 490 CFM at 18.0 PSI
IHI VF-22 490 CFM at 18.0 PSI <--- refigured
SR 30 490 CFM at 22 PSI
Small 16G 490 CFM at 22 PSI
ION Spec (stg 0) 500 CFM at 19 PSI <--- per vendor post 12-27-2002
PE1818 515 CFM at 22 PSI <--- estimated from manufactures rated max power
Large 16G 520 CFM at 22 PSI <--- upgraded flow some on review of compressor map
========= 526 CFM max flow for a 2 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
========= 578 CFM max flow for a 2.2 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
HKS GT2835 400 hp 580 CFM at 22 PSI
MRT 400 580 CFM at 16 PSI <--- added
AVO 400HP 580 CFM at 17.5 PSI
MRT 450 650 CFM at 19 PSI <--- added
AVO 450HP 650 CFM at 20.0 PSI
SR 40 650 CFM at 22 PSI <--- added, got lost some how in editing
========= 658 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
HKS GT3037 460 hp 670 CFM at 22 PSI
PE 1820 680 CFM at 22 PSI <--- estimated from manufactures rated max power
20G 695 CFM at 20.0 PSI <--- added
HKS GT3040 490 hp 710 CFM at 22 PSI
AVO 500HP 725 CFM at 23.0 PSI
SR 50 770 CFM at 22 PSI
GT-30 790 CFM at 22 PSI
60-1 800 CFM at 22 PSI
HKS GT3240 570 hp 830 CFM at 22 PSI
GT-35R 880 CFM at 22 PSI
T72 1000 CFM at 22 PSI <--- note you would have to run a 2.0 L engine
at >40 PSI boost to flow this much air
Awesome chart! Figuring the TD04 (which flows 360 cfm according to the chart), is only the slightest upgrade from an RHB5 I'd figure 340-350 cfm at 14.7 psi. Don't quote me
, its just a rough estimate from looking at some of those numbers.
Mark,
Mark,
