hey i have a block that im doing a project on. it has 280000km i dunno ow many miles bur anywayz i was talking to the local subaru guru in my city and he said it should hold up fine without a rebuild. i was just wondering what your opionin on it was?
thanks for the info
marc l
92 turbo block... 20psi?
But for how long?
Rebuild it. You don't have to yank the crank though, but the heads rebuilt, pistons and rings should be replaced, as well as all the gaskets.
The 2.2T block itself can handle up to 30psi in stock form no problem (Ron @ Axis Power Racing confirmed this). But the high milage can definitely weaken parts therefore making it less reliable. If you want it to last then rebuild it, but if you are one for pushing the limits then go for it.
-Matt
-Matt
1991 Legacy Turbo Sedan
2005 Legacy GT Sedan (STi Conv.)
Look at the measurement unit peoples. . . 280,000kms is like 160000 miles (or thereabouts) That engine is just past getting broken in. I say the bottom end should last a good ling time, and the top end should still be in good shape (provided it was maintained properly). Toss a can of SeaFoam in there and you should be fine. . .
1992 Legacy L Wagon 'Emily" Ice Blue, plush seats, roof rack, towing hitch, upgraded radio/CD player, LS alloy wheels, and lots of love! 180K miles and going very strong!
You will get my Legacy from me when you pry my cold dead fingers from the wheel.
