sloppy steering...
sloppy steering...
I have a slight dead spot in my steering, about an half inch. My ball joints and tie rod are ok, and my steering rack bushing too. Does anyone had to change a steering rack due to this.
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
Get stiffer steering rack bushings.
Even new stock ones have a lot of play.
Yes, a bad rack will stick. The play is the bushings if the tie rods and ball joints are good.
I already have upgraded mrt bushings, i guess i`ll replace both tie rod assy and ball joints. Maybe the control arm bushing are worn too, are those expensive
