that is NOT supposed to be that way. trying to get at some hoses on the valve cover and my big monkey arm leaned on that hose i guess and SNAP. all i heard was this little burbling sound and i knew instantly what i had done.
argh.
what can be done to get this back on the road quickly.
saw in a thread that vikash took the tank out temporarily but that doesnt seem like the best solution.
hollow metal tubing w/threads and a nut on each end? but how do i get the nut on the inside and how do i get it to seal.
will a metal USDM wrx tank fit? it seems like it would.
help.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
it appears the WRX one will fit (w/some braket fabbing) i would use PN 21132AA075.
i could use this metod too as described by legacy92ej22t
legacy92ej22t wrote:This is from an old thread where I explained how I fixed my tank the last time it broke. I'm going to do this same thing to the new broken nipple on my old one that's not in the car anymore so I'll have a spare if the new one breaks:
Ok, I'll let you guys in on the $2.99 fix.
I had one of my nipples break off (that sounds bad) and what my friend and I did to fix it was this. We broke off the remaining brittle plastic where the nipple used to be and sanded it flush with the outside of the tank.
We then took a coat hanger and went in through the cap and fished it out the hole where the nipple used to be. Then we took a hollow piece of all thread that was about the same diameter as the hole and put a rubber washer, flat washer and back-up nut on the side that would stay in the tank. Then we fished it through to the hole using the hanger to guide it. Once we got it near the hole I used some needle nose to work it through the hole ( I used them on the inside of the all thread by opening them up to hold the all thread and guide it through). Then we put another rubber washer, flat washer and nut on the outside and tightened it down.
Now because the outside diameter of the nipple was larger then the inside diameter of the nipple, the all thread had a smaller outside diameter then the old nipple. This caused it to be a little too small for the stock coolant line. What we did was take a smaller hose, cut it to the length of the all thread that was on the outside of the tank and slid it on. Then we slid the coolant line over the all thread with the smaller hose as a gasket and tightened it down.
The whole job took 2 of us about 1.5 hrs. A lot of that was trial and error though. I could probably do it again in about 45 min..
I've driven all winter and about 6k miles like this without a single drip of coolant lost. It's also the line that my Saab intercooler puts pressure on, so it's nice and strong.
96 Impreza L sedan
00 Impreza RS sedan
I broke mine about a month ago, and I drilled the tank and installed a nipple with teflon tape. Seems to be holding well. Here's a pic I took a minute ago..
Binford wrote:I broke mine about a month ago, and I drilled the tank and installed a nipple with teflon tape. Seems to be holding well. Here's a pic I took a minute ago..
well i went the route of threaded tubing w/nuts and rubber washers on each end. no major leaks once it got up to temp. but the tubing i used over the rubber tubing to make the stock hose fit is too stiff and doesnt compress into the threads so it is weeping a tiny bit, nothing major though.
but it will hold till i get either a new plastic tank or a WRX metal tank. w/a cap the wrx tank is nearly the same price as the plastic one.
96 Impreza L sedan
00 Impreza RS sedan
