my cd player has finally crapped out. it wont even accept a disc now.
i like the look of the stock radio and cd player as separate units.
will the newer add on cd player for the impreza work?
or do i have to replace the whole thing w/something else? if i do i want to find a regular single din console so i can have the little compartment under the radio.
Replacing the CD player in the SS
greg donovan
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
dscoobydoo
I took the factory subaru CD player out of the 01 rs and it plugged in and worked with the SS's original tape deck.
In fact I sold it to somebody on here to do just that with it.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
greg donovan
so you still have the audio controls on the cassete/radio headunit?
and when you stick a disc in it automatically switches to CD?
does it actually plug in or do i need to get the soldering gun out?
cool. time to start looking for a subaru cd player.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
dscoobydoo
I plugged the cd player into the deck. The plugs fit perfectly. And yes, when I put a cd in, it automatically started playing it.
But I have no idea if you have to pull the cd out to go back to using the tape or radio. ( as I was just testing to make sure they would work together.)
05 GD-STI
00- GF
05 GD-STI
00- GF
On the SVX units the re is a play/stop button. The CD plays automaticly when inserted, and if you hit this, it stops (and you can use the radio/tape). Hit it again and you are playing the CD again. If yours has a button marked like that, then that function works for you too. Other units may have a stop/eject button. (press once to stop the CD, and again to eject it)dscoobydoo wrote:I plugged the cd player into the deck. The plugs fit perfectly. And yes, when I put a cd in, it automatically started playing it.
1992 Legacy L Wagon 'Emily" Ice Blue, plush seats, roof rack, towing hitch, upgraded radio/CD player, LS alloy wheels, and lots of love! 180K miles and going very strong!
You will get my Legacy from me when you pry my cold dead fingers from the wheel.
IronMonkeyL255
Some people don't like the look.
Personally, I have a subdued aftermarket HU with 1.5 DIN pocket.
I got the Pioneer 6500, as its backlights are green (to match the dash), and the faceplate is more of a gunmetal than silver, so it doesn't stick out so much.
Rio Red '91 Legacy SS
greg donovan
thats an option but i dont really care for the look. would rather keep it oem and not replace the whole center dash w/a intall kit.nzKAOSnz wrote:whats wrong with an aftermarket hu and a 1.5 din pocket with a lid on the front of it?
however that may be the most cost effective route.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
