Perrin Lightweight Pulley install..
Anyone ever install one of these? the stock pully keeps turning even when I have it in Drive(yes this an an auto) the driections say to put it in 5th gear..heh.. any ideas on how to stop the pulley from turning?
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
That's a good question.
Since it's an auto, putting it in gear won't work. Since the tranny is powered by the engine through a torque converter, that means there is no physical connection to the engine......
Rio Red '91 Legacy SS
Isnt the inspection hole actually on the block? that works well, just be careful what you use isnt too brittle and snap off falling into the flexplate/TC area, you are using a lot of torque.. ask me how I know. maybe you can use the breaker bar against the frame rail trick too. which pulley is it for?
http://www.main.experiencetherave.com:8 ... P_2486.JPG
http://www.main.experiencetherave.com:8 ... P_2488.JPG
Stick a prybar or something down in there.
