Chris nailed it here. Let's see where this goes. I am not currently in the market for a new (bigger) turbo, but I WILL be and I would love to see more options available.
and as for a rebuild - I'd probably do that with just about any used turbo. It's just good insurance for a longer hassel free life.
dzx - Hope I'll see (meet) you at this weekends Import drag. I'll be there Sunday (spectating). And I'd love to check out your Leg as well. The Super-R car sounds promising.
nissan 300zx turbo, will it fit, is it larger?
What would the 18G spool rpm be and how would that compare to the Garrett?
the spool on the 18g could vary depending on several varaibles. it flows roughly 41lbs per min. a small 16g flows roughly 36lbs per min. t3 60 is 34lb/min. so a garrett t04e 46 trim would be about the same as an 18g(41lb/min) and to give you an idea 1lb/min is usally good for 9-11hp on a efi intercooled engine(at the crank). varies with head flow,displacement,tune,ect....
93 SS Legacy Turbo
555BCTurbo wrote:All I have to say is Best of Luck and I can't wait to hear how your car performs with the different turbo !!
Thanks! but im still weiging the options....not sure if im going to be able to start it for a while even, i just had to cough up $1800 for first, last and security deposit on a apt....so thats going to set me back a few.....well have to see
