Engine Management Discussion Sought
Larry Witherspoon
Post by Larry Witherspoon »
I have lost faith in inexpensive solutions and now recommend Dastek Unichip as the best compromise between dollars and sense. It is a more expensive process than I would liked to have in my plans for the future, but I like the idea of keeping all the stock sensors and piggybacking off what's already there rather than a big electronics changeout for a daily driver. And I like the idea of optimizing the ignition fuel curves for my specific engine combo.
If you anybody knows of something competitive using the same approach please let me know
Larry Witherspoon
ssspoon@aol.com
Torrance (Los Angeles)
92 Turbo Legacy Wagon
310-429-4269
dzx
Post by dzx »
Apex'i ITC and SAFC II
///M
'93 Legacy SS - part out
TDGKORN
Post by TDGKORN »
greddy e-manage
92 legacy ss 4eat
greg donovan
Post by greg donovan »
the perfect power piggyback ECU sold by Rallitek is pretty cool.
about 480. w/the tuning cable for a wire in unit.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
THAWA
Post by THAWA »
Wow, it's Larry.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
-K-
Post by -K- »
So far I'm happy with my Perfect Power. I have fuel and timing control, can run extra injectors or the boost control solenoid off it.
I have not done much for tuning because all I have on my car is 3" exhaust. After the 440cc injectors and AWIC goes on I'm going to push the stock turbo pretty hard and see..... And I'll be getting a bigger turbo sometime.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
Larry Witherspoon
Thanx for the feedback guys
My long awaited long lost EJ22T block is finally on the FedEx truck from Colorado headed for DPR Racing Development, Gardena CA
No not going to build a racing engine
Going to build a super torquer street engine
Big step in my decade long EJ22T hot rod project
Have most of the parts
Down to work needed on block, heads and maybe cams, then turbo and cooler install, header/exhaust system fab, engine management, and I'm gone
Easier said than done, but at least a step in the right direction
Larry Witherspoon
ssspoon@aol.com
310-429-4269
