Piston pulling video
douglas vincent
Post by douglas vincent »
For those who haven't pulled a piston, here is a video for you!
This was how I spent my fathers day!
http://www.vincentfurniture.com/photos/ ... onpull.wmv
Excellent video Doug.
One question. What's keeping the rod from hitting the cylinder liner and damaging it? Or is it touching and just not doing anything?
Also, did you custom make that tool? From what it looks like, I could just get some round bar and do some grinding to make the hook on the end.
douglas vincent
Do you mean the loose connecting rod? They don't hurt anything just loose like that.
To make the rod, I bent it as hard as I could and then cut and ground the hook into it.
Yeah I meant the loose connecting rod. The reason I asked is because the FSM states not to let the rods touch the cylinder walls when separating the block.
Cool, that's what I was figuring you did :)
IronMonkeyL255
Post by IronMonkeyL255 »
they aren't really banging around in ther very hard, so it couldn't really do anything in the way of damage.
i was just about to ask about you special wristpin removing tool, so thanks for the explaination.
Rio Red '91 Legacy SS
THAWA
Post by THAWA »
Well yeah, the fsm is going to say that because theoretically it can damage the liner. In reality though you'd be alright. Cool vid douglas!
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
hackish
Post by hackish »
Very nice video! I'm sure it will be helpful for those who haven't worked on these sorts of engines before. As for dammaging the liner you just have to be gentle when you let the rod down. I've done more than a few engines like this and never made any marks.
-Michael
dzx
Post by dzx »
Nice video, what did you use to get those covers off?
///M
'93 Legacy SS - part out
Great video, looks like you're well practiced at that.
douglas vincent
Dan, which covers are you referring to?
scottzg
Post by scottzg »
I just got around to downloading this-- im saving it, very nicely done.
Tleg93
Post by Tleg93 »
Doug, you seem like the right person to ask about a good place to purchase a rebuild kit from. Is there a place that offers various kits, ones for performance and standard ones as well for the ej22t? Thanks in advance.
--Scott--
1991 - Rio Red SS
legacy92ej22t
Post by legacy92ej22t »
Nice! You look like you've done that a few times. ;)
Was that the #4 that was cracked?
Can the rings (piston) be replaced without removing the piston?
I'd really like to see a video of you putting the pistons back in. That'd be very helpfull too.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
hackish
Post by hackish »
The covers (I assume you're interested in the plugs in the access holes) require a 14mm hex socket. You can get away with using a 14mm bolt and welding a nut on the other end - then just use a 14mm wrench or socket on that.
You cannot change the rings without removing the pistons.
-Michael
dzx
Post by dzx »
the covers in the access holes were the ones i was wondering about. The ones on my blown EJ22T block were philips shaped and looked like they would need an impact.
///M
I went to sears, home depot, & lowes to try and find a 14mm hex socket. I have not been successful.
I read the oil cooler write up on scoobymods, and he said that autozone had one. So I'm goin to try there tomorrow.
Yep, AutoZone has a 3-piece hex socket set. I think it's 12mm, 14mm, and 17mm or something like that.
Instead of welding a nut to a 14mm-head bolt, could you tighten two nuts against each other on the bolt?
I was thinking about the two bolts.....but I really don't know if it'd be strong enough. I've had two bolts move on me a little bit......plus it sounds like these hex heads are really in there.
