My poor boost gauge...
It's official, I broke my boost gauge in a fit of clumsiness. That really just pisses me off at me. It dropped out of the box onto the pavement on the way into the auto parts store, grrrr. Now I'm out fifty bucks and I don't want to shell out more right now for another one. Anyone got a cheap one left over????
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
- quasi-mod-o
OBX is off the hiZZl3 fo shiZZl3 y0!
I had to...
I had to...
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
I tore apart my boost gauge today. It's actually pretty easy and the rumors that there's some elaborate springs that fly out when you open it are complete bunk. What broke on the gauge is a tiny plasitc arm that joins the needle movement to the coil that's deflected by air pressure. It's a simple mechanical connector, bone shaped, that connects two metal arms by a little expansion fitting that goes through holes in the two arms. The fittings on the plastic piece look like the ones that clip the black body screws on the car. If I can find a way to secure the one arm to the other I'm in business. As far as cabibration goes, I don't see how that's accomplished at all.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
Are you talking about the piece marked "mechanical linkage" in this diagram?
http://www.engineersedge.com/instrument ... ourdo1.gif
Because I believe that piece is usually the one modified when calibrating a Bourdon tube pressure gauge. You shape it to achieve the gain you want (expensive gauges have an adjustable linkage there). Then you position the needle and/or pinion to get the correct bias.
boost gauge
Scott,
I have an OEM WRX/STi boost gauge laying around that reads -.04 MPa at atmospheric pressure. I'm not sure what size gauge you are looking for but I believe the OEM is 1 3/4 in. in diameter. Didn't try breaking into the gauge myself but if you want, I will let this go for cheap. I also have pics, PM me if your interested.
1991 Legacy SS 5-Speed
1999 Impreza 2.5RS Coupe
Boos gauge installed
I installed my damaged gauge and discovered that it is in fact damaged. It reads vaccum but that's it. Oh well, I guess I'll be getting another one.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
I realize it seems I'm talking to myself but here goes anyway.
I just said screw it and bought a Phantom series gauge from Autometer. It works fine and I'm in the process of installing the FCD for anyone who might read this.
I'm gonna put my old one in the new box and take it back as a return. Just kidding, it wouldn't work anyway.
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
