Is the difference an aditional bend to clear the headers?
Id assume the mounting spots to be the same.
If you tried to install an NA bar on a turbo car where exactly would it hit?
How about a turbo bar on an NA?
Why are the Turbo and NA sway bars different?
different front crossmember. Most likely to clear the up & down pipes.
