4.0 vs. 4.3
legacy2
Post by legacy2 »
ok, so to sum it up, honda's dont make a lot of torque, but they only weigh like pretty much nothing so they dont have to make a bunch of torque, but its always more fun if you build the torque up your self by adding add-on's
91 Legacy Wagon, AWD
Binford
Post by Binford »
Why are we talking about Hondas? :?
scottzg
Post by scottzg »
legacy2 wrote:ok, so to sum it up, honda's dont make a lot of torque, but they only weigh like pretty much nothing so they dont have to make a bunch of torque, but its always more fun if you build the torque up your self by adding add-on's
Hondas don't make a lot of torque, but it doesn't matter because they make peak torque at a high rpm, so it makes sense to stay in low gears and have peak torque multiplied by gearing. They don't make a lot of torque though, so at the low end where you don't have the gear advantage, the are kinda doggy.
It's hard to add torque through bolt ons, save forced induction, all you can do is shift where peak torque is.
Post by entirelyturbo »
Another problem no one has mentioned, inline-4's are not inherently balanced like our engines are. Therefore, the vast majority of manufacturers that use inline-4's also use balance shafts to try to counteract the unbalanced forces in the engine, and since the balance shaft is one more thing to turn, it is a parasitic power loss.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
BAC5.2
Post by BAC5.2 »
Isn't the Flat-4 not entirely balanced either? The only truly balanced engines would be Flat-8's and V12's?
I remember hearing someone talk about that, probably on here. Was it you Scott?
The not-weighing-a-ton thing, was because my honda that only makes 68lb-ft, is sitting in the frame of a CBR 600F4 motorcycle. It's not a civic.
THAWA
Post by THAWA »
No engine is every truely balanced. And inherent balance only applys to a few orders of balance.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Our engines have balanced primary and secondary forces, but imbalanced moments.
scottzg
Post by scottzg »
BAC5.2 wrote: I remember hearing someone talk about that, probably on here. Was it you Scott?
Yeah, i've mentioned it before. Inherently balanced engines are all flat engines, inline 6's, v12s, flat plane v8's, and some sort of 16, whose specifics elude me. That's not to say that just becuase its inherently balanced it will be smoother than another configuration, but it is likely to be the case. Fewer cyls usually = less smooth.
Yeah, the balance on an I6 has to do with the crank angle, but I can't remember what that is.
I think it was Hardy or Scott who found a perfect website to show the way each engine design is balanced or unbalanced. Do either of you remember which one I'm talking about??
THAWA
Post by THAWA »
yep
scottzg
Post by scottzg »
it was my post :)
scottzg
Post by scottzg »
