redline water wetter water wetter water wetter!!!!
What did he say?!?!
Redline Water Wetter!!!
Micum
Air to water Question
teaguespeed
rsstiboy
its the same height as the radiator or thereabouts, but the length goes about 4" past the bonnet catch and lines up with the radiator on the other end, its also just as thick as the radiator.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
Are you sure you're not referring to the AC condenser?? My Legacy RS has the radiator closest to the motor then immediately in front is the AC condenser (which is near as the same size) and in front of THAT the intercooler radiator......which is quite a bit smaller than the radiator and AC condenser.....the Legacy intercooler system takes about 2 litres of fluid so isn't big...
1991 Legacy RS. VOSchip. 154.6kW ATW @ 1bar boost
rsstiboy
maybe they made the liberty's heat exchanger bigger than the legacy? probably due to our climate. its a bit hard to confuse it with the A/C condenser, I would like to think I am mechanically knowlegable enough to at least know which one services the intercooler!
