1/4 times
rsstiboy
1/4 times
please no bogus results or flaming, i am genuinely interested in what these things are capable of.
my best to date is a 13.79 @ 98.6mph, however I have lost the timeslip. so I ran it again on saturday just passed and have some times for you guys.
60ft - 2.037
330ft - 5.796
660ft - 8.917 @ 79.17 MPH
1000ft - 11.571
E.T. 13.839 @ 99.23 MPH at 18 degrees celsius
was done with spike to 14psi tapering off to 12psi by redline (7000 rpm) 3" turbo back exhaust, pod filter, MRT inlet plenum, lightened flywheel, heavy duty clutch (slipping in 1st, hence the bad 60ft time) water/air cooler, STi ratios on 1st and 2nd, VF12 turbo. it was a 7000rpm launch, clutch dump.
60ft - 2.037
330ft - 5.796
1000ft - 11.571
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
LegacyT
r0gu3 - How did you manage a 13.4 with just a DP - catback, and intake.
Cause i mean thats a pretty good jump from 16.2 for a stock touring wagon to 13.4 with just those mods. Have you upped the boost at all, any ECU mods?
Thanks,
Mark
Thanks,
Mark
Morgie!! Mods!! Now!!
I mean, if you could please list your mods, thank you, have a nice day.
My best to date is 15.7 @ 86.X - I'll get more specific when I grab my slip out of the car.
Exedy Flywheel, Heavy duty clutch w/ kevlar disk, K&N air-filter, full tank... the rest stock!
I blip repeatedly then rev to around 5500-6000 and slip that kevlar like a beast. 2.10x 60' is my best.
morgie
Mods, hummm let me remember.. hehe
TurboSmart manual boost controler
Home Made controler, used to lean the A/F ratio a little (running 1560°F EGT)
3" straight downpipe + midpipe , 2.5" resonator + 2.5" straight muffler
255l/h fuel pump (like if that does a difference .... for now...
K&N Filter
1/2 tank
MultiBox removed (in the trunk) but spare still in place (there is a lot of junk in my multibox.. haha )
16" RS 2000 Wheels.
ah and the biggest mod, it was about 15°C outside
stock clutch, stock everything else.
i use the same strategy as yours for launchs 4000rpm then slip a bit the clutch to avoid the engine from dying.
on a previous drag day (1/8mile), i did a 2.104s 60ft with 0.602 reaction time.
K&N Filter
1/2 tank
16" RS 2000 Wheels.
morgie
'98 4Runner V6 Manual 4x4.
legacy92ej22t
Off topic but what does it feel like when the ecu plays with timing? I may be experiencing this.morgie wrote:I got 15.3 @ 88mph last sunday, at 9psi boost.
did better after with 10psi boost, but couldn't get the time (it was a 5$ illimited races day, no time... )
at 11psi, it got worst as i could feel the ecu playing with timing :\
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
rsstiboy
sounds like you are experiencing "surging" its caused by using a bleed valve in conjunction with the factory boost controller.
ran again the other day did a 14flat on 13psi, will run again when i put my chip in
FrmRgz2Rchz
rsstiboy
Andy, is your car EJ20t DOHC or EJ22t SOHC? looking at those times it must be a EJ20t you should be able to run 16psi without problems with that turbo.
FrmRgz2Rchz
I have the EJ22T. I've been experimenting with more boost and it acts like it will handle it. After many runs with 17psi, I didn't hear any kind of knock or ping and my intercooler was as cool as can be. I don't have any guages to measure a/f ratios and gas temps though, so I'm not going to keep it up there.
I made the diy fcd and it works, but it feels like it's not getting enough fuel when the rpms get past 4000. If I only partial throttle it, it pulls fine. I'm thinking it doing what you and morgie were talking about, so I'm not using the fcd anymore. Back to 10 pounds it is.
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
morgie
went at the track today again... nothing changed on the car, running 9-10psi, 20-21°C...
60ft : 2.085
1/8 9.656
1/4 15.24
88.19 mph
not so bad ...
here's the proof
(dont look at my reaction time, i got distracted hehhe , usualy i do .600-.700s)
http://public.fotki.com/morgie/morgie/r ... large.html
60ft : 2.085
1/8 9.656
1/4 15.24
88.19 mph
not so bad ...
here's the proof
morgie
Do your reaction times matter? Doesnt make any difference if you go on the lights or after, just dont go b4 and alls good.
My best is 15.005 @ 95.7mph with a 60ft of 2.1. Way below what it should be capable of but theres something holding it back, bloody autos.
The car is a 96' GT Legacy Twin Turbo with 2.5 turbo back zorst , k&n pod filter and a unichip running 143kws at the wheels, so somethings wrong but hopefully ill figure out what sooner or later.
Deaks
Deaks
legacy92ej22t
I'm racing real 1/4 mile drags for my first time this saturday and was wondering, can any of you give me any pointers? Should I redline every gear or shift at about 5800 rpm or what? I'm a little worried about staging, is it hard to keep your revs up while staging? Any advice would be cool,thanks
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
