Stupid question, but what's the easiest way to remove the ECU without having to take apart the whole dash?
I took off the drivers side, knee-height trim panel (the one with the "TRAY") and found the ECU (the silver box with all the yellow connectors on it... located roughly 6 feet away from where the Haynes manual said it was).
I unscrewed two obvious 10mm nuts. That allowed the ECU to wiggle a tad, but it didn't seem to come free. What next? Am I missing another nut? Do just have to shove the ECUharder? Or do I have to do more dash work? (god I hate taking apart the dash)
how to remove ECU?
rallysam
how to remove ECU?
'00 Impr RS - sold
legacy92ej22t
When I took mine out, I think I undid the fuse panel box and then I was able to pop it out.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
You have to kind of shove it out in the opposite direction as the nuts since you have to clear the studs. I just removed the lower dash panel which is a couple screws.
rallysam
Ok, that sounds like what I was doing. If there are only 2 nuts, then I guess I just wasn't shoving hard enough to get the studs clear. I guess I will stop babying it!!!
'00 Impr RS - sold
If you haven't taken the connectors out of the ECU....do that....it makes it much easier.
rallysam
Man, after more shoving, I don't know how you guys got that ECU out of there.
It's not an issue of being gentle, because I wasn't. The problem is that this white plastic thing completely prevents the ECU from moving!!!
(the guard in the center of the photo with a bolt in the middle of it)
I don't see how it would be physically possible to get ECU studs out of their holes without removing that plastic thing somehow. Orrrrr...... using a dremel to cut off one of the ECU's studs:
Problem solved, but man that sucked!
'00 Impr RS - sold
huh....I don't recall mine having that plastic thing...
