Fuel pump relay/fuse location??
02SIXT
Post by 02SIXT »
Is there a relay or a fuse specifically for the fuel pump? I'm having trouble with my pump, for some reason its not getting power, but the pump itself works fine, I took it out and tested it with 12v power.....but in the car its dead.....anyone know if theres a hidden relay or fuse somewhere for the pump itself?
1991 Legacy Turbo
"You can do ANYTHING with a Dremel"
The relay's mounted way up high under the driver-side dash near the firewall. But before you go looking for it, check the harness connector under the passenger side of the rear seat.
