Dreadful thumping rear wheel
91 Legacy sedan, non turbo has loud thumping in right, rear, wheel well when car reaches 65 mph. Sounds exactly like piece of loose tire hitting the well. But no, brand new tires made no difference. I have removed and examined brakes and all parts in area but can not find a clue to noise. Thump! Appreciate any ideas...thump.
BAC5.2
Awkward handling, bump associated (uncomfortable ride, or changed ride), ONLY at 65mph?
Inspect everything on the rear of the car. If it makes noise, usually something is rubbing something else. Check for wear on anything related to the suspension.
greg donovan
use a 1/2" drive socket for the nut, clenched in a large pair of vise-grips. You then sneak a small socket through the hole on the big socket, to hold the shaft. If it is allen head (I forget, the AGX are allen), you can fit the allen right through square drive hole in the 1/2" socket
it makes more of a thunm over bumps, but if you also have a bent wheel or out of balance wheel, especially with a worn strut, that could get the wheel hopping and make the sound regular
greg donovan
