att- josh legacy 777 bc5 front end on a bc6 pics
here is the pics i been looking for josh.
93BC"edm" 93GC 90BC R.I.P.
That's just a BC5 (89-91 overseas) legacy that has the plate in the rear section. It just so happens that the trim level they get doesn't have the chrome stripes.
Those rear lights are taller then the bc6's rear lights.
LegacyT
Josh,
Those are indeed BC6 tailights on that car. The oversea's spec legacy's/ liberty's (89-90) also got the taller taillights with chrome strips (many people painted them black though) and a similar center-section (bottom part was painted from the factory). Have a look:
Mark,
Mark,
eastbaysubaru
I just took some video of a car with very similar tails. I was driving and the only thing I had with me was the video camera. The car I saw had a black middle section though. I hadn't seen one like that in the U.S. so I took some vid. just to prove it to myself
Apparently there was a Legacy in the U.S. that had that taillight configuration.
-Brian
-Brian
'04 PSM FXT
something doesn't seem right.....the trim and styling of the top pics seem different then the bottom ones.
I don't know......I've measured the lights on mine vs. the 92-94 models, and the rear ones can't be swapped. To swap the front, you'd have to do the fenders and everything else.
Most of the datum points are the same. However the length of the datum points for sides that the fender bolts on are a touch longer, despite the fact the engine bay points are the same.
LegacyT
That car is very strange, seems like the owner liked to look of the 91-93 rear and the 89-90 front (overseas spec post/pre face-lifted years). And just plowed on with all-out conversion. Either he swapped out the front or rear. Like you mentioned Josh, the front needs quite abit of work, for the rear you'd need a new trunk and rear bumper, along with some custom taillight mounting work. Either way several new parts are needed. I'm curious which way he went though.
Mark,
Mark,
I know which body style it is
It's definitely a 91-93 chassis car with an 89-90 front end.
He swapped hood, fenders, grill, etc. everything up front. The rear would be too hard to swap because you wouldn't be able to fit the different lights into the holes. You would have to cut out the rear fenders and that mess.
Now.....do you want to know how I know for sure what year it is?
Take a look at these two legacies
http://www.surrealmirage.com/subaru/ima ... turbo2.jpg
http://www.surrealmirage.com/subaru/ima ... tinew2.jpg
Same angle for the pics, one is a 94, one is a 91. See if you can tell me what's different besides the tail lights, front hood, fenders etc.
Then look at the pics in this thread for corrolations. Who'll be the first to see
close, but not that one....yeah you could swap that easy. There's something else.....and the trend is the same for our US legacies, which is one of the reasons why I'm saying it's the 91-93 chassis
Okay Josh, I have looked at these pictures for WWAAAYYYY too long now and have concluded that the car is in fact an older 89-90 Legacy. My first reasoning is my initial reaction. Not always reliable. The second is the little reflectors behind the front wheels existent on 92-94 but not on the olders. I can't remember what else I was going to get.
Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
Denver, CO
Ok, here's a hint.
"Legacy"
I'm headin off to bed. If no one gets it by the morning, I'll post the answer.
"Legacy"
Scott got it.scottzg wrote:yours truely got it within seconds. Look at the rear corner window. The early ones have the badass raised area where the legacy logo is right under the glass. The later models dont.
I don't think the sheetmetal is changed or anything, just that the legacy badge is not there and there doesn't look to be a chrome strip at the base of the triangular window.
Yes you can debadge that piece, and yes you can paint over the chrome, but the fact that the US legacies have the same setup, it leaves me to believe with good confidence that it's 91-93 MY. Also, like I said the tail lights between model years will NOT interchange. You would have to do major modifications, which in my mind is not worth it.
legacy92ej22t
YA under the little triangle window behind the rear window that can be rolled down....I,ve always known that though.they stopped doing that in 92 on all models.I thought it was going to be something better,you could pop those off and fill the holes and paint and you wouldn't even be able to tell.
vrg3 already got it though right off the bat
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
