Hello all,
I know i will be ridiculed for asking about an impreza here, but i picked up a fuel pump assembly from a 93 touring wagon, im starting to think my impreza pump is getting lazy or clogged...are the tanks the same enough to do a stait swap or just the pump?
and is the turbo legacy pump have a higher output than say an N/A??
Cory
Fuel Pump Question
simbey1982
Matt Monson
- quasi-mod-o
Yes,
The turbo pump has more output. No, it is not a direct drop in. You need to make a jumper harness to make the connectors work. And lastly, unless you have a ton of mods that include cams, you are just going to make your car run pig rich, get horrible gas mileage, and foul plugs way faster than stock. More gas does NOT automatically equal more horsepower...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
It regulates pressure. If the stock regulator can not return enough volume back to the tank, pressure will rise and you'll run rich.
Matt Monson
- quasi-mod-o
simbey1982
IronMonkeyL255
Hmm.... I may need a new FPR.
I dropped in a Walbro unit, and seem to be running rich since then. I know I get far worse fuel milage, and I thought it was my O2 sensor.
What pressure do our fuel systems run at? I know the newer Subarus run at a higher pressure, but I just can't remember the pressure.
Rio Red '91 Legacy SS
You can get the fuel pressure info in the factory manual I posted in the stuff you need to know forum.
IronMonkeyL255
