Crank Pulley
Crank Pulley
ok, im replacin the timing belt and what the hell do i have to get to get the crank pulley off. I already obviously have the socket and 3 extra just in case, but what do i get to stop the crank from turning? this is on a toyota
91 Legacy Wagon, AWD
its a 5 speed...but i have one wheel off and its up in the air so i can get to the bolt and the pulley. and because of this the wheel in the air turns when i turn the crank pulley, even when its in gear. i do have an impact wrench but i didnt know if i should use it on the crank.
so in other words i need something to stop the wheel from rotaing.
yea. did you try the "put it in 5th gear"? i believe that since its most likely an open diff, you have to get that wheel on the ground. put it in 5th and with the e-brake on. should start to come right off. bolt should be pretty tough to loosen so give it some muscle.
00 5MT AWD 2.5 RS - New Project
This is what I was going to suggest.irishsetter wrote:I just put a socket and breaker bar against the frame of the car and bumped the engine over and it came right lose. The pulley pulled right off.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
you need to put some more MUSCLE into it. You won't damage anything if you're on the bolt correctly
to do mine I put it in 5th and hauled the ebrake up as far as possible. With a 1ft breaker bar on top of my large 3/4 ratchet I had no trouble getting it off. Got the new one on as hard as I could and checked it every day after wards. you wont need a puller to get it off, it slides right off, you may have to bump it a little but nothing special
