fuel filter problem???
90legasyman
After the car sits overnight, before i start the car i need to turn the key on for a couple sec before i can start it, then i turn it on (it takes a couple seconds before it will start). then it runs, put it in drive or reverse, step on the gas then it feels like it will stall after a step or 3, then it runs smoothly after that. so what could be the problem? is it something related to gas? such as the injector or filter or something.
legacy rocks
legacy rocks
How many miles are on it?
Does it do this just when the car sits over night? What about when it sits during the day?
What area of the country do you live in?
It's possible your coolant temp sensor is needing to be replaced.
90legasyman
I'd suggest replacing the coolant temp sensor.
It's like 20 bucks from one of the online subaru dealerships.
www.subarugenuineparts.com
90legasyman
90legasyman
welcome
