Rear diff removal
Rear diff removal
What is the easiest way to get the axles out of the rear diff?
John
http://www.cardomain.com/ride/560635
Don't pull the outer out unless you have to. Pull off the lateral links and maybe the trailing arm (dunno for sure, been a while). Then move the axle out of the way. Least that's how I'd do it. If you have to remove the axle from the outer portion also either pop off the center cap or take the wheel off, then remove the axle nut. I think you still have to remove the lateral links anyway.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
