Removal of rear diff head threads
MY92
Post by MY92 »
I need to take the 2 threads out of one diff head to go into one I have which don't have them for some reason.
I've tried a pair of vice grips but the thread felt pretty soft so I didn't want to wreck it.
Any ideas on how to take these threads out?
Cheers
John
http://www.cardomain.com/ride/560635
THAWA
Post by THAWA »
Thread two nuts on the studs, tighten the outer one to the inner one (or vice versa, whichever makes more sense to you), and start wrenchin on the inner nut.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
You can't just get two new studs?
mikec
Post by mikec »
What about swapping the cover?
QuickDrive
Lurker-King
Post by QuickDrive »
mikec wrote:What about swapping the cover?
I like the way this one thinks.
R I P-------- 91 Turbo 4EAT --------R I P
mikec
Post by mikec »
:D
Of course, if you've managed to pull it out without spilling any diff fluid, then this will be the messiest way to go about it.
tris91ricer
Title Whore
Post by tris91ricer »
I would say the double nut method is easiest if you can do it right. I've never been able to get it, though. . . :(
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
It helps to use an impact wrench.
