Looking for that manual rack feeling?
legacy92ej22t
Post by legacy92ej22t »
Here's what you do. Run an undriven pulley and an aftermarket steering wheel that's smaller diameter then OEM. Walla! It makes your steering very tight and responsive.
Vikash got to drive my car at the Shootout and he said he really liked the feel of the steering too. It's very nice. I recommend it for anyone looking to tighten things up a bit.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
tris91ricer
Title Whore
Post by tris91ricer »
You mean underdriven PS pulley?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
legacy92ej22t
No, underdriven crank pulley.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
An underdriven crank pulley really isn't going to do much.
jamal
Vendor
Vendor
Post by jamal »
"voila"
Would turning the p/s pump more slowly even make any difference above idle? Maybe the steering wheel has more to do with it?
Manarius
Re: Looking for that manual rack feeling?
Post by Manarius »
legacy92ej22t wrote:Here's what you do. Run an undriven pulley and an aftermarket steering wheel that's smaller diameter then OEM. Walla! It makes your steering very tight and responsive.
Good idea, but going ud crank pulley does more than just slow down the PS pump. I don't know if I'd want that on my car...
scottzg
Post by scottzg »
matt, what happens when you have to whip the wheel one way then the other? Can the underdriven ps pump keep up, or is it like hitting a wall?
BAC5.2
Post by BAC5.2 »
I wonder if I could drain the fluid from the power rack, and bypass the power steering pump altogether?
You can't do it with fluid in the rack, I tried. But I heard Douglas Vincent bypassed the pump and was still running the power rack?
I just want a manual rack.
scottzg
Post by scottzg »
Brando did something like that because the ps was in the way of something else. I thought it was horrid, and i like manual racks.
legacy92ej22t
jamal wrote:"voila"
Hahaha, you got me. =)
I don't think it's just the wheel though. I swapped in my OEM steering wheel for inspection and had it in for about a month, a while back, and it was still much more solid and responsive then with the oem crank pulley.
Scott- No, it's fine. It's just tighter...more solid.
Manarius- I'm aware of the negative aspects of running an ud crank pulley. My alternator doesn't like it one bit.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
azn2nr
Post by azn2nr »
somehow i think a underdriven ps pulley would be better.
oh and when the ps goes out in a car like the ss it sucks hard.
i have a manual rack in my civic and love it but when ps goes out on a big car its....well just bad
-jason
legacy92ej22t
Ya, I lost the PS on my Econoline 350 bucket van (boom lift) and had to drive it like that for about a month. I'd get home and my shoulders would ache. It sucked.
An ud ps pulley might be better but I already have the ud crank pulley and it works just fine.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
BAC5.2
Post by BAC5.2 »
azn2nr wrote:somehow i think a underdriven ps pulley would be better.
That is because there is still fluid in the rack.
An un-powered, power rack doesn't make a manual rack, but rather a hard-as-shit unassisted rack.
But if there was no fluid in it, how would that make it while unpowered?
Subtle
Post by Subtle »
Online mag Autospeed has a electronic box that modifies the duty-cycle of any solenoid. I haven't ordered it yet, but
it can dial easier steering at slow speeds with stiffer at
higher speeds. Or whatever.
scottzg
Post by scottzg »
pretty sure that there are no electronics in our steering.
professor
Post by professor »
the power steering pump is capable of pumping enough fluid at idle, so when going 60 mph, it is pumping way more than you need it to. The relief valve opens and bleeds off most of the high-pressure side into the low-pressure side.
under-driving the PS pump regardless of method will have the effect of possibly causing too little flow to maintain pressure near idle. This will lower the pressure and maybe make the rack feel tighter (increase effort), when idling in a parking lot
however, once the point is reached where the relief valve begins to open a little (now maybe 800 engine rpm instead of 600 rpm), the pressure will be the same as before and there will be no difference.
to do what you want you'd have to change the fluid pressure, not the delivery rate. the only way to do that is to change the calibration of the releif valve. This may be possible but I personally wouldn't mess with it, unpredictable power steering can be pretty dangerous.
206er
Post by 206er »
were there any manual racks in an impreza or something?
I love manual steering in small light cars but unsure what it would be like in a legacy. a lot of power racks are quicker ratio than their manual counterparts, for example in A1 chassis vw's.
would it be bad for the rack to run it without fluid? maybe put some breathers on the lines to keep pressure and debris out of it. just an alternator would be pretty sweet. :)
on a side note, has anyone seen those quick steering gear overdrives for steering? they are a circle track type deal but are available in several ratios. might make for good feel and great steering with a power rack. a little twitchy maybe...
dzx
Post by dzx »
The power steering on my car is long gone. It's not bad and you can't tell when your just driving down the road. Turning the wheel while stopped is pretty much the only time i notice it but im pretty used to it by now.
///M
'93 Legacy SS - part out
BAC5.2
Post by BAC5.2 »
Dan - You emptied the system of fluid, correct?
With as much castor as I have, I'd be worried about breaking something trying to turn while stopped without any power assist, and having the rack seize, of course.
What are the concerns with that?
With the racifying of the Legacy, I'll be gutting as much as I can. Every pound counts. Goal: 2500lbs incl. driver. We'll see how it works out.
THAWA
Post by THAWA »
I've got a manual rack now, and the car is 200% more smokey! :( It feels like shit.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
My smaller aftermarket steering wheel made a huge difference in terms of weight and feel - pretty much like my (manual rack) GLs with their tires inflated fully (somewhat low inflation would be pretty heavy in parking lots). Phil's driven it and can attest to this, I would think.
douglas vincent
Post by douglas vincent »
Just saw this, due to a bad PSP on the wifes sedan.
Anyway,
I have been running a filled steering rack with no pump for about a year. Never a problem. Just very stiff and hard to park.
