Yet another "does it fit" question, sorry guys
Well I have finally saved up enough dough to get some rims, and i have a few questions about fitment(yes I have searched quite a bit, but time is a factor here). I was looking into the Rota Sub-Zero's, 17x7.5 with a 225/45-17 tire. My 90 LS sedan will also soon have GR2's with either H&R's or some Whitelines on it. I just wanted to know if I have a lot of rubbing to look forward to with this setup or will it simply require a fender rolling? Any help with this is greatly appreciated seeing as I am still quite a Subby Newbie.
You didn't search very hard, because that's my summer setup, and I've posted about it many times.
You'll rub the fender, a good amount. You need to roll them.
yeah...
Well I guess somehow I missed your post when i was searching, sorry about that. Rolling is when you bend in the small lip around the fender well and can be done with a bat, heatgun, and some patience from what i understand. Thanks for the responses guys.
