15 mpg? What's going on?
Any idea why I'd only be getting 15mpg? The last two tanks have gone like that. I know this car isnt that fuel efficient, but that seems kinda extreme.
Manarius
Leaking fuel? Bad Coil Pack? Yucky Spark Plugs? Bad Sensors? I'd check those things...
Manarius
Check their voltages...read pinouts from the ECU..etc...Splinter wrote:How do I check the sensors?
You might want to try to clean the MAF. You might also want to try replacing the PCV valve..that can kill mileage too.
All_talk
Hey Splinter
That car always did about 26mpg hiway, I'd think it should be good for at least 20-21 around town if you're not spoolin the turbo all the time.
You dont have a check engine light do you? If you are running rich in feedback mode (after warm up, off boost) the O2 sensor should through a code.
Gary
Gary
Nope, no check engine lightAll_talk wrote:Hey Splinter
That car always did about 26mpg hiway, I'd think it should be good for at least 20-21 around town if you're not spoolin the turbo all the time.![]()
Gary
Although it just occured to me that I've reset the ECU a couple of times (while working on the electrics Ive disconnected the negative terminal from the battery)
Could the mileage drop that badly while the ECU is relearning?
Anyone know the answer to this?Splinter wrote:Although it just occured to me that I've reset the ECU a couple of times (while working on the electrics Ive disconnected the negative terminal from the battery)
wiscon_mark
