As most of you guys know I use the rally car for work.So the other day the engine was running fine sitting in LA traffic.Then it started to run limpy? check engine light came on and it ran like crap.This went on for about 5 mins and then cleared.It ran fine for the rest of the day.Now I notice it idles at 1500 or a little higher infact the idle is never the same.After a blast down the freeway it sometimes idles at near 2000.
Any clues? I've got Prescott in 2 weeks.
Cheers
Chris
Just a small problem
Manarius
Coolant Temp Sensor or MAF? Checked either of those lately? Did you check the code the ECU is throwing?
greg donovan
That damn mouse under the hood screwed something up...
Could also be:
1. Idle Air control valve
2. TPS Wire shorted/ chewed
3.some other wire the mouse ate (MAF)..
It could be the temp sensor, but check the other stuff too.
Could also be:
'96 GF/STi Rally wagon, under construction
If it's mechanical, it WILL break...
www.allwheelsdriven.net
rally370
Hi Barrett
Thanks for the info.I did take a look at the Idle control valve last night.Remember when I got the car the check engine light was on? and there were small pieces of metal in the valve.Well same thing again.So this might be the problem?? anyway do a road test and see this weekend.
Cheers
Chris
Cheers
Chris
