cam profiles
cam profiles
Are there cam profile docs for the NA vs Turbo cams?
- quasi-mod-o
They are in the FSM's that you can download from Josh's mainexperience site.
I have them at home and can look them up is someone doesn't post them today...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
- quasi-mod-o
- quasi-mod-o
Hmm. Cam lobe height is between 32.39 and 32.49 mm, but that is for both turbo and nonturbo.
In fact, the ONLY valvetrain specs that the FSM differentiates between turbo and nonturbo are the aforementioned profile specs. I can't find any specs on the valve head diameters, so I guess the thread about turbos having smaller exhaust valves still has merit.
- quasi-mod-o
Actually it is the intake valves.
And just a side note, if one were looking to increase duration without buying Delta cams, you could put 1.8l cams with their roller rockers into the 2.2l heads. You must use the 1.8 roller rockers, but they fit...
Suby Hai!
Suby Hai!
