Spark Plugs
petridish38
Spark Plugs
Post by petridish38 »
I'm trying to diagnose a slight hesitation at low RPMs in my car and i am going to try to replace the spark plugs to see if that will help.
Any suggestions on what brand or type i should use...? I'm just looking for some cheap efficient spark plugs... no performance plugs or anything fancy...i just want some that will run good on my Legacy...
209,000 miles!
2002 Impreza WRX Sport Wagon
ciper
Post by ciper »
NGK Coppers, they are cheap and performance!
ditto on the ngk coppers
rlima
Post by rlima »
Is there a part number for the NGK Coppers?
1991 Legacy Turbo AWD Sedan (5sp M)
Real roads don't have centre lines!
mile hi
Post by mile hi »
We have done a lot of checking on plugs and the NGK's are the best all around that we or anyone we know has tried. The part number is
BKR6E11.
Al(CO)
Post by entirelyturbo »
I know this is an old topic, but I've got $.02 and I want to spend it here! :o I have tried the Bosch Platinum 4's and I saw absolutely no increase in performance, only a worsening of gas mileage. I was told that German plugs have colder heat ranges designed for German cars, therefore leave German plugs to German cars, and Japanese plugs to Japanese cars...
I have since put NGK coppers back in, and find performance to be just as adequate. I do have Magnecor 80mm wires though, and I recommend those!
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Aaron's ej22t
Post by Aaron's ej22t »
WHOA!!! :shock:
those are huge! 80mm = 8cm which = approx. 3 inches.!! those are some huge friggin plug wires! :lol: :wink:
j/k, i know you meant 8.5mm. that is what the magnecore are. i bouth 7mm ngk wires, they are blue and nice :o
92 Legacy Turbo \ 5MT \ Silver
Dude.....I got the 100mm wires.....they ROCK!!!
hehehe....j/k
um...oops :oops: , shoulda sat down and thought about that one...Magnecor 80 series, the blue ones...
