Cleaning a dirty 2.2 T motor...
tasq
Post by tasq »
So, I picked up the touring wagon today... I wan't to clean the hell out of the motor, but I have heard there is a knock sensor under the cooling tank that is very sensitive to moisture. What have you guys done?
Thanks in advance 8)
- 94 Touring Wagon
- 05 Wrx Sedan
Manarius
Post by Manarius »
Could SeaFoam it...that stuff smokes like hell but cleans up the engine well.
tasq
Post by tasq »
It will be ok if i just cover that sensor then right? :)
- 94 Touring Wagon
- 05 Wrx Sedan
Manarius
Post by Manarius »
tasq wrote:It will be ok if i just cover that sensor then right? :)
SeaFoam is an oil product (I think it's just a good bit of alcohol) that you put in your gas tank, intake, and/or crankcase oil. As far as I know, there aren't any sensors it effects but...
tasq
Post by tasq »
oh!!!!!! I meant the exterior of the motor :-D
- 94 Touring Wagon
- 05 Wrx Sedan
Manarius
Post by Manarius »
tasq wrote:oh!!!!!! I meant the exterior of the motor :-D
I just power wash mine. I don't ever cover up anything. By the same token, I don't spray the alternator for fun.
All_talk
Post by All_talk »
The knock sensor will throw a code while its wet but the engine heat will dry it out quickly then all is well. I've got mine wet just running water down the scoop washing the car and have washed the engine at the car wash... no lasting ill effects.
Gary
tasq
Post by tasq »
thanks guys! :)
- 94 Touring Wagon
- 05 Wrx Sedan
wiscon_mark
Post by wiscon_mark »
yeah, if you have a distributor (which you don't I'm sure) you need to cover that up, and probably the intake, but other than that, it was ok, when I did it.
Just give the car a little while to dry, and all is good :)
185,000 miles
