go on SLi, and explain how you did this, there's a thread for it
over engineered intake design
wiscon_mark
scottzg
Go for it then... you'll be better off if you figure it out on your own anyway. My thing used sheet metal, particle board (easy to cut with a jigsaw) epoxy, and that valve. If it was really 'all dat' i could have hooked it up to the throttle pretty easily.wiscon_mark wrote:no, I'd like to over-engineer something cool like this. I'm crazy like that
You could take the airbox off and replace it with a nylon stocking...
mouth564
Well...
Thats one way but i am not sure if it will work with every option.Jason, when Roman gets the SHO fixed, you can see what the V8's are made of. He has zero intake restriction (i.e. Throttle body is attached directly to the MAF which is attached to the cone) and some exhaust work done.
wiscon_mark
