Are you talking about a stock-type sensor or wideband? The stock O2 sensor on an SS is located about 0.5" from the turbo.dzx wrote:When its directly after the turbo. Like a couple inches. I would post a pic, but nasioc is down.
Oxygen Sensor Questions I Haven't Seen Yet
rallysam
'00 Impr RS - sold
rallysam
rallysam wrote: Ok, well I guess I will give the stock location a shot and see what happens.
Update -
I installed my wideband in the stock location and it seems to work ok. Haven't noticed any problems yet.
I was getting AFRs of:
* 14.5-15.0 at idle or light cruise.
* 11.x at WOT
* readings all over the map during a gear shift (rich or lean)
I got those readings with the O2 input to the ECU disconnected, then I connected the "simulated narrowband output" to the ECU's O2 input and got basically the same readings.
AFAIK that seems right
'00 Impr RS - sold
Sam,
What wide band do you have?
rallysam
Zeitronix meter, which uses a Bosch sensor. Seems pretty cool so far... but I only have about 5 miles of experience with it.Legacy777 wrote:Sam,
http://www.zeitronix.com/Products/zt2/zt2.htm
'00 Impr RS - sold
Thanks.
Looks pretty cool. Let me know how you like it.
