Moderators: Helpinators , Moderators
THA Roux
Posts: 1 Joined: Fri Oct 21, 2005 6:02 pm
Post
by THA Roux » Fri Oct 21, 2005 6:11 pm
Hi!
I'd like to know if a set of spring out of a 2001 impreza 2.5rs could fit on my 1995 Legacy wagon's stock struts...
I just hope it could drop the car a little and improve handling....
Am I right...... or wrong?
thanks!
sillyp
Posts: 121 Joined: Wed Oct 15, 2003 10:02 pm
Post
by sillyp » Wed Oct 26, 2005 2:04 am
according to the suspension information compendium, they should fit, but i bet the rear will sag a little. i would use the fronts and not the rears and see how it rides
actually you might need a different front perch. i dunno
92 5mt AWD
F250 duty
12" Johnson
scottzg
Posts: 2278 Joined: Tue Jan 28, 2003 8:19 am
Post
by scottzg » Wed Oct 26, 2005 8:18 am
it will drop the rear pretty good...
NuclearBacon
Posts: 478 Joined: Wed Nov 09, 2005 5:50 am
Post
by NuclearBacon » Sat Nov 19, 2005 5:13 am
To continue on this post, my friend has a 98 legacy L Wagon, and we took Lowering struts (shock and springs) off of a 2001 2.5 RS.
The question is can we replace the legacy stock suspension, with the adjustible height suspension from the impreza.
Will the lowering suspension have to be at its highest for the rear?
Would the rear just not work?
is this a direct bolt on? or are the "caps" ive been reading about needed? (replaced with a new set from another car)
(i also own a 92 touring wagon, and wonder about the same swap)
Any input?
thanks!
JasonGrahn
Posts: 1333 Joined: Tue Oct 15, 2002 4:55 pm
Post
by JasonGrahn » Sat Nov 19, 2005 6:31 am
Why???
Why not just buy a set of springs made for your car???
-Jason Grahn
napphappy
Posts: 512 Joined: Fri Jun 03, 2005 12:57 am
Post
by napphappy » Wed Nov 23, 2005 2:07 am
They said they "took" them. Maybe they didnt pay for them? Which IS much cheaper than "buying" a set made for his car. Or maybe he thought he could ask a question and get an anwser, or at least some helpful input.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
NuclearBacon
Post
by NuclearBacon » Tue Nov 29, 2005 1:12 am
My friends mom purchased a 2.5RS with a lot of mods on it.
his mom did not want mods. she wants stock. hence, aquiring lowering struts.
any ideas?
thanks!
Luigi
NuclearBacon
Post
by NuclearBacon » Thu Dec 22, 2005 4:58 am
bump!?
subawhatsubawho
Posts: 1443 Joined: Sun Apr 03, 2005 11:08 pm
Post
by subawhatsubawho » Tue Dec 27, 2005 8:47 pm
Here's a suggestion...
Do it yourself and let us know how it goes. Then you can do a write up on it with pictures if it works. If it doesn't please let us know as well so when some NooB does a search (which they never do) we can point them towards this thread and they will have the answer they so desire.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
eph
Posts: 96 Joined: Sun Apr 03, 2005 8:54 pm
Post
by eph » Thu Jan 05, 2006 9:30 pm
im not too sure about the 1998 legacy but i knwo rs sturts bolt right up to the 91-91 legacy. i have rs sturts on my 91...
1991 Legacy L Wagon, FWD to AWD and Automatic to Manual Conversion... then AWD 5M/T N/A to 5M/T Turbo awd swap...
http://www.cardomain.com/ride/879076
