Group N tophats
Group N tophats
Where can one get Group N tophats, and what is the benefit of these? Yes i used search, absolutely nothing came up, or maybe i'm a n00b, you be the judge. Thanks
- Title Whore
Personally....unless you are doing other modifications to your suspension, ie stiffer/lowering springs and struts, I wouldn't bother with them.
The main advantage/benefit on stiffer suspensions is that with the softer stock rubber top mounts, the rubber compresses before the spring does, and the rubber is for all intents and purposes undamped, so you get the "bouncies" Putting the sti top mounts on there eliminate this, and make the springs/struts do what they're supposed to.
I recently purchased and installed STi group n top mounts on my 1991 Legacy Sport Sedan. Front part number ST2031055000, $113.00 from www.subarugenuineparts.com. They don't have the rears, so I got them, part number ST20370AA240, $110.00, from www.rallispec.com. The holes line right up and they fit fine. Late entry: I forgot to mention that the part number for the rear mount is for use with upper seat(perch)20373AA20 which is 92-92 Legacy and 93-01 Imprezza. The seat and mount are separate pieces. I don't know what the STi group N top mount part number is for the '91, which has the upper seat as part of the top mount.
also when oredering these you need to remember to not panic and think you got ripped off when you notice that the part number stamped on the mount is the same as the number stamped on the regular mount.
they use the same mold but different rubber so the old part number is molded into the GN mount.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Yeah....the rubber is much stiffer. Plus the box it comes in has an STi part #.
Imprezive--I have converted to use 92-94 legacy or 93-01 Imprezza springs on my 91 SS. So now the upper spring seat and the top mounts are separate pieces. The original piece was an upper seat and top mount combination as one unit. I'm guessing, but I think you can buy STi top mounts for the 91. Did I answer your question?
Yeah, I think that we should start a thread to collect the spring's and tophat's diameter to find out what works with what.
My brother tried puting stock wrx springs and shocks/struts on his 91' ss and the rears didn't fit. The bolt pattern on the shock was different and so was the spring diameter.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
I thought that was a good idea several years ago.Imprezive wrote:Yeah, I think that we should start a thread to collect the spring's and tophat's diameter to find out what works with what.
http://bbs.legacycentral.org/viewtopic.php?t=2153
