in the video that I saw on here a while ago but cant seem to find anymore. It is I think the worlds fastest 1st gen leg that is painted wrx blue at the drag strip where the guy is able to press a switch and make it only fwd to do a burnout then flips a switch to make it awd again. I remember someone knowing what type of tranny that was. Any help would be good thanks.
Mike
what tranny was that...
It was probably a built 4EAT. you can just wire in a switch to the FWD fuse thingy. If you are doing highway driving that switch would come in handy for better MPG. Just make sure you aren't wearing down those front tires.
-max
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
no I know abouyt the switch trick, this was a video that was on some site that was bragging about having the fastest 1st gen leg. this thing does a serious burnout then lauches in awd. I remember somebody on here knowing what kind of tranny it was. There is some shop that makes these. I need to search some more on google.
