Height
jpoyann
Height
Post by jpoyann »
Hello!
It seems to me or my Legacy Turbo is about two inches lower at rear than the no Turbo version?
Here in Spain there are not so many Legacys to compare, but yesterday I´d got the opportunity to. The front height was the same.
Thanks for the help!
Subaru Legacy 2.0 Turbo 4WD Sedan
Manarius
Post by Manarius »
My 1991 NA sits low in the Rear..I'd definitely say that the gap between the fender and tire is much lower in the rear than in the front.
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
they dont sit any lower in the rear, the wheelwell is just cut higher in the front to allow for turning under high suspension load.
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
snowboarded
Post by snowboarded »
The lowest sitting stock legacy rear end is the 91 fwd.
I never knew the wagons sat that much higher tho...
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
jpoyann
Post by jpoyann »
LaureltheQueen: I realized that a long time ago.
Legacy777, your links are really usefull to me. Thanks you!!!
jpoyann
Post by jpoyann »
I think I´ll have to change the coils of my car!
Only thing to note, these are for the US model cars. They should be similar for other countries, but may not be identical.
jpoyann
Post by jpoyann »
Ok
